Mongo1958
Junior Member
The bikes handlebar riser bushings were starting to cause some wobble. It actually became more noticeable when I replaced the mirrors with magnum long stems from Kuryakyn. Anyway, I removed the ultras faring, passing lamps, ignition knob handle to gain access to the handlebar risers.
Trouble with this kind of maintenance is all of the dirt a grime that I found that I had the clean. I got the Arlen Ness polymer bushings and I started the install at 12 noon and got it all back together around 4pm. I also spent some time wiping it down with some ceramic spray after I was done.
