Right turn signals not working
Discussion in 'Electrical' started by marcus22, Aug 3, 2012.
  1. marcus22
    marcus22 Junior Member
    430
    3
    My dad has a 94 tour glide. right side turn signals do not work, but the left do. he replaced bulbs and still no lights. any thoughts?
  2. xcavater
    xcavater Member
    82
    Check the plug where harness comes off the handlebars.
  3. lordharold
    lordharold Active Member
    191
    might check to see if it has a turn signal flasher it could be bad. it would be inside the headlamp assembly and look rectangular in shape
  4. marcus22
    430
    3
    thanks! I will let him know and when we figure it out I will let you know.
  5. HDDon
    5,562
    133
    236
    Since the left side works I doubt it's the flasher. I have a '94 FLSTC and recently I had to replace the turn signal switch on the left handlebar. It's a little tight in there but easy enough to replace.
