The 08 RG has 3 adjustment screws , top center , lower left & lower right , the adjustment screw are threaded into a green plastic tab that seats into the outer fairing , the lower left screw adjust the left light the lower right screw adjust the right light , the top center screw can only be adjusted with the outer fairing off & should not be adjusted according to the manual . After taking the outer off & reinstalling the left light shines to the left & will not pull right , the right light shines low & will not pull up & level with the left light . Both lights should be level to each other , that was the way they were before I took off the outer fairing . I took the outer off 3 times , all the tabs are seated correct & know matter what I do the right light will not raise up & level to the left light . FYI if the left screw is turned it will affect the right light & if the right screw is turned it will affect the left light . Every action has a oppisite reaction .
