replacing rear jug gasket
Discussion in 'Touring Models' started by abe69, May 19, 2009.
  1. abe69
    abe69 Member
    5
    Looks like I'll need to replace rear base jug gasket and pushrod block gasket on my 91 ultra. My question is can anyone provide me with the take apart order and if I'll need any special HD tools. Thanks for your help!!
    50
    This is where the factory manual would be the right way to go.:s
  3. abe69
    abe69 Member
    5
    thanks for the info.
  4. STEVE07
    4,128
    68
    86
  5. TQuentin1
    4,737
    142
    I have a '91 also, and replacing the base gaskets is not that tough. But I strongly agree with what Glider said above. Get the Factory Service Manual covering your model and year. The HD manual is better than the aftermarket ones.
    Couple of thoughts here:
    • This job is WAY easier with the engine sitting on a bench or on the floor rather than in the chassis
    • Once you have the heads off and start to pull the jugs, BE CAREFUL that the pistons don't flop around and damage the case or the pistons
    • REPLACE the main studs and the head nuts
    • Stuff some rags or tape off the cylinder ports in the case after the jugs are off so nothing falls in the case!!
    • While you are this far, it pays to do valve job, rings, hone cylinders at least
    Good luck with your project, and the folks here are always interested in these kinds of projects, so keep up informed. And LOTS of pix are great!!
