C chil01 Member Mar 21, 2010 #1 Can I change out my tappets without removing the tappet guides Thanks
S shovelrider Member Mar 21, 2010 #2 You will need to remove the lifter blocks to replace the lifters.Unfortunately there is no way around this.
Breeze3at Experienced Member Mar 21, 2010 #3 If you mean the lifter blocks (#70 in att), no. You have to remove the blocks, then the lifters come out. Note which way the oil holes face when removing. You really should have the lifter block alignment tools (2ea.) for reassembly. Attachments lifter blocks.jpg 30.7 KB · Views: 28
