Repaired motorcycle tires should be used only to get you home if need be. They should be changed for safety sake at the earliest possible convenience.
Remember on a car, you have 4 tires and a repaired tire there isn't as critical as when you only have two tires, it's not worth gambling on your life to use a repaired tire.
Most spoke wheels cannot be repaired with a flat fixing kit because the air will leak out around the spoke nipples. There are only a few spoked wheels that are tubeless, this is because of a vulcanized strip that covers the spoke nipples and prevents the air loss.
Mag wheels can be patched/plugged as a temporary repair until replacement is possible.
Use a repaired tire to get you home then replace it for safety sake.
Here's a few choices for repair kits.
Motorcycles & Street Bikes | Find Road Bike & Sport Bike Motorcycle Reviews – Motorcyclist Magazine
http://www.jpcycles.com/groups.aspx...c131&DID=6474f115-8b45-48b5-883a-b37ba32d094e
