Removing Primary Cover
Discussion in 'Softail Models' started by jldietz, Aug 25, 2009.
  1. jldietz
    jldietz New Member
    I am attempting to remove the primary cover to access the chain; however, after removing all of the bolts, I cannot remove the primary cover. Any suggestions?
    Remove the primary chain inspection cover too :s
    You'll see why when you take the bolts out..
  3. shark59er
    shark59er Member
    18
    Take the inspection and derby cover off.
  4. TQuentin1
    4,737
    142
    Welcome to the Forum. Lots of good info here on the Self-Help pages and in the heads of your fellow members.
    Make sure "all" is ALL. If you take off the derby cover and the inspection cover if you have one, you can stick your fingers in there and have a bit more purchase to yank on the primary cover with. But if not, grab a rubber mallet and give the cover a gentle smack or two. Should pop away from the inner primary.
  5. Dr. Dolittle
    6,404
    118
    29
    Ouch - are you suggesting that he strike his beloved Harley?!? :p
  6. NEWHD74FAN
    8,191
    98
    19
    Dr. D...rubber mallet = good, sledge hammer = bad, tough love 'round here! :D
  7. TQuentin1
    4,737
    142
    Just a wee love tap front and back!!
  8. Dr. Dolittle
    6,404
    118
    29
    So much to learn.....so little time!
