Glsec507
I have an 06 road king. I want to swap out my throttle position sensor but I'm having trouble finding the right tool/s in order to do so.
According to the service manual I just have to remove the air cleaner and backing plate and then unplug and unscrew two torx screws which hold the sensor in place. Problem is the screw on the left side of the sensor (closest to cylinders) is so close to the rear cylinder I can't fit my torx bit and right angle wrench in there.
Anybody do this swap before without removing the throttle body or top of the cylinder? Any suggestions???
Thanks
Thanks
