HI
Need help with my 07 Road glide
I have an electrical problem need to test the regulator. Does any one have a trick to test it. Please let me know
thank you
If you need to check and make sure your charging system is working, start your bike, put a meter across the battery terminals, throttle the bike up to about 2000 rpm and you should be charging probably over 13 volts.
HI
thank you
