Redline Tranney Fluid
Discussion in 'Touring Models' started by PeteINny, Apr 27, 2010.
  1. PeteINny
    PeteINny Active Member
    155
    I was talking with the service manager at the local Harley dealer about switching to some type of synthetic tranney fluid. He recomended Redline. All I can say is wow. I can't believe how different it sounds and feels. I never would have thought synthetic tranney fluid would have made that much of a difference. Has anyone heard of anything negative?
    No negatives about syn trans fluid , especially redline and Spectro.
    Only thing is in the cold weather, you get a hard shift for the first block or two with the redline.
  3. PeteINny
    155
    good to hear....
  4. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Glider is Right on here!
    and The one reason is "in the difference" ... Redline being called shockproof Heavy.
    The Heavy is a 75w250 right on the bottle... You would have to get the tranny up to 600+ degrees before that gear-lube runs like water.
    Red compares to a 75w90 but at 250 it will not give up the thick protection Needed Between Gears.
    Now that is Protection!
  5. glider
    Well thanks for that tidbit :D
    signed....GLIDER
  6. HDDon
    5,542
    133
    229
    Is tidbit Bubbies new nick name? Neat:newsmile100:
  7. glider
    Good idea, it's better than "sissy" :lolrolling
  8. Jack Klarich
    Ouch:p
  9. jaceddie
    jaceddie Junior Member
    928
    Boy, that will leave a mark!:newsmile100:
  10. maine-e-axe
    maine-e-axe Junior Member
    732
    "tidbit":D I never had any trouble with 75W 90.:s
