Have you done any troubleshooting?
Are you losing spark or fuel?
If not fuel injected, see how your fuel line is routed. Sometimes routing can allow the engine to heat the line, causing a vapor lock (bubble of gas in the line).
If fuel injected, sometimes you can have a broken wire to a fuel injector, inside the insulation. After the engine gets hot, the insulation can become more flexible, allowing the broken wire to separate. Does she start stuttering before dying, or just die?
Does she run rougher until she dies? Sometimes your crank position sensor (near your oil filter) can have an accumulation of metal bits on it (take out and inspect, wipe off). The same sensor can be damaged during an oil change, and become temperature sensitive.
Coils can sometimes become temperature sensitive.
is she throwing any codes?
Sometimes, what appears to be a warm-up issue is really just a time related issue masquerading. Any other issues at other times?
More info = better diagnosis.
Good luck,
Rich P
