I had to replace a dammaged tire so I pulled the rear wheel off last night (first time) it was difficult to get the caliper past the wheel.
I am going to remove the pads from caliper to make more room. There was a rubber duhicky that came out of the caliper mount. How does this go back in? and at what point of the procedure?
Any other tricks?
I was going to replace the axle shaft in the opposit direction with the nut on the exhaust side, any reason not to do this?
Does the shaft need lube?
Any other tricks?
