My 2007 Road Glide 27k was running fine. After sitting two weeks I started it up to warm it up so I could change the oil & it only ran on front cylinder. Took to local shop & had it hooked to computer & all electrical checked out fine. I brought it home & added a small amount of fuel injector cleaner to spark plug hole on rear cylinder. I put the spark plug back in & hit the start button it sputtered a couple of seconds, Rear Cylinder kicked in and both cylinders ran fine. Road 15 miles & it ran great. Two hours later I went to warm it up to change my oil and the rear cylinder was not running again. I replaced both fuel injectors with new OEM injectors. I fired my bike back up and it is again only running on front cylinder. Any suggestions on what could be wrong would be of great appreciation.
Thanking You In Advance,
Tom3
Tom3
