Yesterday I went for A Ride And I Lost Rear Cyliner Firing But Has Spark
D dirtracerthree New Member Aug 24, 2015 #1 Yesterday I went for A Ride And I Lost Rear Cyliner Firing But Has Spark
Jeff Klarich Experienced Member Contributor Aug 24, 2015 #2 Have you checked for codes? That would be the place to start.
HDDon Experienced Member Contributor Retired Moderators Aug 24, 2015 #3 Here is a list from the forum self help section:http://www.hdtimeline.com/archive/t-46425.html
Jeff Klarich Experienced Member Contributor Aug 24, 2015 #4 Have you checked the wiring at the rear injector? Try the wiggle test on the rear injector wire, they have been known to break or crack and not send a signal to the injector. I'd think that would show as a code if you check your codes.
J Jack Klarich Guest Aug 25, 2015 #7 Dan.1977P said: Can they get stuck in parade mode (EITMS)? Click to expand... My guess would be yes if it had a bad temp sensor JMO
Jeff Klarich Experienced Member Contributor Aug 31, 2015 #8 Have you found the problem? If so the find/fix can help the next person. :s
