rear brake pads
Discussion in 'Sportster Models' started by forever harley, Nov 8, 2008.
  1. forever harley
    forever harley Member
    Installed new pads on the rear of an 05 sporty, a bit challanging but everything seemed to line up fine, I think. Went to flush out the old fluid and had a difficult time getting the old out. The fluid would come in small amounts and not flow freely. After a few hours of pumping and using a vacuum pump the new fluid started coming through. Bleed it a few more times to make sure all air was out, peddle still doesn't feel right and the pads will not retract from the rotor. When I push in on the caliber the piston does move. Is there still more air in the lines, bleeder valve bad,Pad spring slip?
  2. NEWHD74FAN
    8,191
    98
    19
    When you removed the old pads, did you wipe the exposed pistons with clean brake fluid? When you pushed them back into their bores, you may have shoved all the dirt and debris in with them and they are now binding up the works.:(
  3. forever harley
    I'm afraid to ask...... now what? take off the caliber and clean it or can I remove the pads and spray around the piston with something.
  4. glider
    It's all in the self help forum for the reading.
    Brake Caliper Maintenance - Harley Davidson Community
  5. NEWHD74FAN
    8,191
    98
    19
