Re: Setting Timing On An EVO
Discussion in 'Engine, Fuel and Exhaust' started by james013168, Mar 5, 2009.
  1. james013168
    james013168 Member
    12
    my sportster keeps backfiring and won't idel, I guessed the timing is off, anyone have any ideas?
  2. dave_shovel
    dave_shovel Member
    7
    Did this just start or did you mess with your timing? It doesn't idle, but how does it run? If it backfires through the pipes-check for exhaust leak. If your carb is "coughing" then it's probably lean. Idling issue is usually an intake leak problem. Use a carb cleaner and spray around your manifold. Does your idle go up?
    I doubt that your electonic ignition is causing this, although it can.
    dave
  3. glider
    What kind of ignition do you have in it?
