Raising rear
Discussion in 'Trikes' started by FLST, Sep 11, 2015.
  1. FLST
    FLST Active Member
    248
    4
    Is there a safe way to get the rear wheels off the floor enough for easy cleaning? I have a bike jack and a floor jack but am not sure where a safe jacking point would be. Don't want to throw anything out of whack.
  2. Jeff Klarich
    4,805
    103
    486
    I've used my bike jack and it works well. I use straps to tie it down so it won't tip, and center the jack under the case. You only have to lift it a tad so the wheel will rotate.
  3. fin_676
    5,779
    153
    285
  4. plow boy
    plow boy Member
    81
    18
    3
    My screw type scissor jack has been well worth the 60 dollars, it gets a lot of use.
  5. dbmg
    dbmg Guest
  6. HDDon
    5,544
    133
    229
  7. FLST
    FLST Active Member
    248
    4
    Thanks to all for the tips.
