Race Tuner runs rough
Discussion in 'Touring Models' started by jimatkins, Jul 27, 2009.
  1. jimatkins
    jimatkins New Member
    I have a 2008 Ultra with the 110 kit and race tuner installed. It has very little power at rpm less than 2200. It also sputters and sometimes back fires when I try to take off quickly. It has been on the Dyno several times with no relief. any one have a suggestion for fixing this?
    50
    Intake leak?
    Have you had a custom map installed/made or are you running a canned map?
    Was the tuner that dynoed it reputable?
  3. jimatkins
    sorry I should have mentioned that: The tuner is the Harley tuner, I have the 110 kit screamin eagle heads and Rinehart true duals.
  4. 03classic
    03classic Junior Member
    424
    when they had it on the dyno what did they tell you?
