Carroll B
The stock bars on my 2005 XL883 are to low and too far forward making it uncomfortable to ride so I plan to change them. I see no way to add risers or perhaps buckhorn bars without extending the wiring. I'm an electronic engineer so cutting and splicing the wires is no problem. My question is as long as I use the same guage wire do you see any problem cutting the wires, splicing in 6-10 inches of any color wire as long as the same color wires are in the wiring connectors? I hope I explained that so you can understand. If I have a green wire with a black stripe, would there be a problem extending this wire using a black wire in the middle? I've seen a wiring harness on Flea Bay for about $20 that I could use for the splicing and it would have all the correct color wires but now I can't find the ad.
