free website stats program Question on Tach install 06 Deluxe EFI | Harley Davidson Forums
R
Ricks2524
Guest
Almost done with installing a tachometer on my Deluxe, I have one wire that goes to the coil. Before I go any further I read somewhere that it should connect to the rear coil lead. Is this the case or does it matter front or rear.
Thanks Jeff, but I don't see a negative . I have 4 wires front coil , rear coil , ion sen, and power
Thanks for the help. Just to be sure, I can connect to any of the wire except the power , correct?
I thought everything was working fine until I took it on the road. The tach wouldn't register over 1800 RPM no matter what I did, I then studied the wiring chart again and found I have an open tachometer output connection on my ECM. I ran my signal wire to the ECM and got nothing at all, Any ideas?
