I have a 2013 HD Iron (435 miles) and its about half low on oil on dip stick. I checked it hot. Is that normal to use a little oil on new engine? If so, what oil should I use to top it off?
Keep in mind when you change your oil you will not get all of the old oil out also, use 1/2 quart less than your owners manual says and re check after it is warmed up
