Protective Film Removal From Fender
Discussion in 'Softail Models' started by gasbag, Jun 14, 2009.
  1. gasbag
    gasbag Active Member
    356
    Hello,
    I have a 2006 Heritage. My son and I are removing the bags, bars, pillion seat etc. while we do some work on the bags and a few other things. We are not going to put the pillion seat, passenger footpegs, backrest and luggage rack back on, but install an over the fender rack which fits right behind the main seat.
    My problem is: underneath the pillion, on the fender, there is a clear plastic film installed to protect the fender from the seat. It is obviously a factory piece and it is tough stuff. It is thicker than your average film and I can't even pry up an edge to see if it is removable. It is really ugly and it will show since I am removing the passenger seat.
    Has anyone ever successfully removed this piece? Any help would be much appreciated.
  2. softailsteve
    softailsteve Active Member
    107
    try putting som heat on it with a hairdrier or a heat gun
  3. fin_676
    5,779
    153
    285
    should come loose with some heat but don't use too much heat as may damage the paint
    you may well end up with some glue residue on the paint some white spirit or paint thinners will remove the glue but don't rub too hard as you could end up damaging the paintwork
  4. Davidw2415
    Davidw2415 Senior Member
    1,456
    46
    Hairdryer; i would avoid the heat gun it's to easy to apply to much heat with one which could blister the paint. If you have a halogen light on a stand you could use that. Just sit it close enough that you can feel the heat hit the fender ,should take put a few minutes to soften it up. It also works great for removing contact paper from selves.
  5. gasbag
    356
    Thanks for the responses guys. I am going to go steal my wife's hair dryer tomorrow and see if I can make any progress.
    It's just weird, the last thing I expected to see under that seat was a sheet of plastic.
    Everyone have a good day and ride safe.
  6. whatyardwork
    whatyardwork Banned
    829
    4
    This is what we use in body shops when removing decals.It will not harm the paint.You can buy 1 disc and a chuck at any local body supply then attach it to your cordless drill.One disc will last the average hobbiest a lifetime.
    Auto Body Toolmart - eraser
  7. jonny oz
    jonny oz Member
    82
    i removed mine with a heat gun, and used some goof off for the leftover sticky stuff. you're not going to hurt the paint unless you point a heat gun at it for a LONG time. it doesn't take long to get that thing heated up enough to remove - you'll melt the protector before the paint gets damaged.
  8. vaibhavcoder
    vaibhavcoder Member
    42
    some one had discussed few days back about how to remove show soal mark from the silenser and the solution was to use hand wash soap.
    I am not at all sure about how it will help you but try it once may be it works.
    Noddy
  9. glider
    I find that some heat applied removes the coating well followed by some adhesive remover or WD 40 if there is any residue left.
