free website stats program Program to Check/Reset Codes? | Harley Davidson Forums
Is there a program that i can load into my laptop computer
(vista program useage)to check and reset codes on a fuel injected h.d from 1999 to present. The kind that harley dealerships uses.
Including buell models.
If so where can i get it at.
TechnoResearch has one that does what you want and a whole lot more. Hopefully I will have mine by the end of Aug. They aint cheap though, the one I'm lookin at is 1k + a few extras that I havent priced yet. You do know that you can use the bikes on board diagnostics through the trip odometer reset button right?
You can check and clear codes on all HD models from 2004 to present by just doing the diagnostic check through the speedometer. On the 2000 to 2003 models you need a jumper to read the flashes of the check engine light and you can clear the codes with 50 cycles of the ignition or a scanalizer. No program is needed as far as I know. This info is available on this forum.
