I am VERY dissatisfied.
Last weekend, I up-graded my '03 FLHTCUI OEM 5-speed tranny to an SE 6-speed that I bought from Republic HD (Sugar Land Texas) for about $3K and change (including the side cover kit, misc. gaskets, oil, etc.). 200 mi. later, my brand new tranny is covered with oil!! Pulled fill tube, primary cover and starter to see where the oil was coming from. Guess! That stupid little chromed plate and gasket (35153-03 and 35152-03 respectively) that are supposed to seal the old speed sensor location on the case leaked like a sieve!! The screw was tight, but not sealing. This is a crappy solution by HD. Must have been the night-school engineering crowd. They should have designed a profiled cover like the speed sensor itself that fits down in the hole and uses an o-ring to provide a better oil seal. Not sure how to get all the oil off the transmission at this point. Called the Motor Company for their wisdom. They said something to the effect: smear RTV on both sides of the gasket!! WHAT CRAP!! But what did I expect - they designed this rinky-dink setup. So my question is: What is the solution to provide a positive seal on the old sensor location?
