Problem after problem 2012 sportster 72
Discussion in 'Sportster Models' started by brokenscout, Nov 3, 2013.
  1. brokenscout
    brokenscout New Member
    hello all. I bought a 2012 sportster 72 brand new off the showroom floor. Recently i noticed a clicking sound coming from the left side of the engine as i accelerated, than at speed. i was close enough to my 5k service so i decided to have that looked at. Savannah harley davidson determined it was a bad clutch hub bearing. After ordering the clutch hub bearing it was further determined that the bearing ordered doesn't fit in the hub proper. So,,,, now a new clutch hub on top. All warranty work. Fine. well i just got my bike back from savannah harley davidson (with a few new scratches :***:) and there is some serious vibration in the left foot peg. Anyone got any ideas what might cause that?
  2. gator508
    gator508 Well-Known Member
    2,762
    179
    brokenscout,
    Take it back to the dealer, if they are reputable, they will make it right, good luck!
  3. Nikko684
    Nikko684 Active Member
    273
    3
    Was it the clutch for sure? I mean did you also check the primary chains adjustment? that makes a clacking noise too. Either way if you have a warranty, abuse it. They should make it right.
  4. bio_research
    bio_research Member Contributor
    68
    It could just be a loose spot on the primary chain... I just had to replace mine...
  5. vonh
    vonh Member
    18
    Man that's some sloppy work by either a lousy mechanic or bad shop!! I think I'd get the work done at another dealer. I mean scratches and vibrations?? What the is going on. Don't they test drive their repairs? Go to another shop this one doesn't care. Get a good mechanic who cares!! and all your troubles will go away!!!! and you'll be riding instead of waiting.
