RibEye
Senior Member
I've got an '03 RKC with a leaky mainshaft seal in the primary. I have just about researched enough to be dangerous. However, I'm concerned about sealing the primary bolts behind the clutch. From what I read, you need to glop on some RTV, on the bolts and in the bolt holes. It sounds kind of iffy to me. I won't want to have to go back in to re-do. Are there tricks to prep and application of the sealing material, to ensure good success?
I intend to do all the seals I can get to: primary mainshaft, shifter shaft, tranny mainshaft. I am also thinking about replacing the mmainshaft bearing in the primary with the high-torque one from Barnett, which does not require a pressed on inner race for the shaft. Just seems like a good way to go.
Any thought gents?
Enjoy,
Rich P
Any thought gents?
Enjoy,
Rich P
