Got a 1990 FLST which hadn't been serviced in a while. There was a slow leak which came from the primary case. Wiped clean and watched it leak from the lower two bolts and the drain plug (very dark oil). Drained the primary and oil was black. Replace main case gasket, and other cover gaskets. Replaced the drain plug with new. Added ATF-F fluid (red) about 30 oz. Also changed the motor oil and filter. New Plugs. Started the bike and saw leak, pretty fast drip. Shut off bike. All primary case bolts clean and dry and no evidence of leak. Drain plug clean and dry no leak. Red ATF fluid leaking from somewhere behind the primary. Did I over fill the ATF oil? It mst be forced out from somehere? Where's it coming from? Thanks for the help.
