Primary chirping
Discussion in 'Transmission' started by glidenwide, Oct 5, 2009.
  1. glidenwide
    glidenwide Member
    When I down shift and release the clutch it sounds like birds chirping in the primary. Any ideas?
    50
    Maybe a bird stuck in there?:D
    How about looking into the adjuster to see if it is adjusted right and the level of oil is right.
  3. springer03
    springer03 Active Member
    141
    sounds like not getting lubed. metal to metal
  4. Dan89FLSTC
    Dan89FLSTC Banned
    97
    Check drive belt alignment and tension.
  5. TQuentin1
    4,737
    142
    Not trying to be an alarmist, but based on my own personal experience, anytime there is strange noise of any sort coming from inside the primary case, I suggest dumping the fluid and opening it up to look. If the compensator nut backs off, the rotor can wallow around on the shaft potentially damaging the stator and the magnets on the rotor, and if the rotor jams on the stator, the drive shaft will shear the teeth out of the rotor in a heart beat. Trust me, I know. So if it sounds like it is inside the primary case, pop it open and check!!
  6. glidenwide
    glidenwide Member
    I did open it and no birds flew out so thats a good thing.:D The oil level is up to the ring on the clutch. I check it regularly because of the noise. I am planning on changing the gasket this winter, i can see a little seeping around it after a ride. How much play should the chain have? Should I go with the HB tensioner since I will have it open? thanks for the responses.
  7. Gezzer Glide
    Gezzer Glide Active Member Contributor
    341
    When mine was chirping it was the drive belt. Tightened it a tad and the noise went away...
  8. Jack Klarich
    I had a similar issue with a97 FLHT when the belt got wet from ridding in the rain it would chirp for a couple days an adjustment to the belt solved the chirp good luck
  9. glidenwide
    glidenwide Member
    The noise has been there for a while. I tightened the belt and that did not stop it. It definately comes from the primary. I got caught in the rain the other day and I heard the drive belt sqeeking
  10. Elmosac
    Elmosac Active Member
    174
    I just started having a similar cherping noise, I'll have to give the drive belt a check to see if it needs adjusted.
    Did you guys find the belt loose or tight when it was cherping?
