kzoo Banned Sep 12, 2011 #1 I forgot to inspect the primary chain for adjustment when I did my 3 hole fluid change. If I pull the inspection plate, will I lose the fluid?
G glider Veteran Member Sep 12, 2011 #3 Pulling the inspection cover and not the derby cover will never loose any oil. Pulling the derby cover, it's easy to put a piece of 2X4 under the stand to be sure.
fin_676 Experienced Member Staff member Moderator Contributor Sep 12, 2011 #4 It will be a lot easier to see what you are doing in the inspection cover if the bike is upright Brian
