Power loss in the throttle.
Discussion in 'Engine, Fuel and Exhaust' started by mydeluxe, Mar 31, 2010.
  1. mydeluxe
    mydeluxe Member
    71
    On may FLSTNI the trouble started with a slight power loss in the throttle…then progressed to were it had no power and then cut off…after cut off I could start again idle only…if I give it gas she cuts off…any ideal on were to start to find out what’s wrong??? Only thing I think of is I used some of the gas I had lift over from winter with fuel stabilizer in it…and that may be fouling out the plug…
  2. Big Rol
    Big Rol Active Member
    166
    Definitely sounds like a fuel supply problem, so thats where I would start.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    From your description, it sounds like fuel starvation. 2005, is is carb. or inj.? If carb. you can drain the float bowl (see self help tips), if inj. check the tank filter. Keep us posted with your actions and findings.
  4. Hoople
    Hoople Account Removed
    7,198
    34
    I would try fresh fuel first. After that if it's fuel injected, I would look at fuel pump pressure, fuel filter, inside convoluted tank hose etc.
  5. BOBFLHTC
    BOBFLHTC Active Member
    273
    My bike cut out while I was riding several weeks ago. My tank lining is starting to flake off and clogging the filter on the Petock. I dropped the Petock and flushed the tank and there were alot of white flakes. I plan to do a better job later in the season. It may not be your problem but its a possibility. Good luck with it - Bob
  6. TQuentin1
    4,737
    142
    Hmmm. Check this out and see if it describes your problem. If you do have to pull stuff out of the tank, change the fuel filter and pressure regulator anyway.
    Engine Dies And Runs In Spurts - Harley Davidson Community
    As a note to readers, the "I" in the model designation indicates that it is fuel injected engine. That will apply to the model designations.
  7. mydeluxe
    mydeluxe Member
    71
    05 fuel injection...
  8. mydeluxe
    mydeluxe Member
    71
    TQ Thanks for the link very educational but do you think this is possible with only 4300 mile on the bike?
  9. Hoople
    7,198
    34
    I would think hose deterioration is function of time not mileage. Maybe TQ will agree.
  10. Breeze3at
    4,926
    224
    If I had COMPLETELY read you model designation I would have noticed that. :p
    Thanks to TQ also. :small3d005:
