power commander V blowing ECM fuse
Discussion in 'General OFF TOPIC' started by emmo2112, Mar 2, 2014.
  1. emmo2112
    emmo2112 New Member
    3
    I've got a 2009 FLSTSB, installed couple basic mods, and a PC V to take care of the fuel/air... been working great for about a year, now all I get is a blown ECM fuse, trys to run on one cylinder, if you rev it up it blows the fuse... updated firmware on unit and interface software, same problem... anyone had a problem like this?? any cures other than a new ECM??
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    If it ran good for a year, I'd look for a chaffed wire that is shorting. Have you done any recent mods/work that could have caused a shorted wire?
  3. Jack Klarich
    Welcome to The Forum, Pete has you covered here, check ALL wires, is your unit mounted under the seat? Have you run it with the seat off?
  4. emmo2112
    emmo2112 New Member
    3
    well I did some checking on wires off the ECM block, didn't find anything obvious
    will go after it with an ohm meter, ..anyway if I take the PC5 out of the loop no problems... but now I have no fuel/air control.. called Dynojet, I'm going to send in unit... there pretty confident its not in the unit... I've search online for days, nobody's had this problem..hahahaha maybe I'm the first
    anyway thanks for the reply's...
  5. Dr. Dolittle
    6,404
    118
    29
    Not sure what you mean by "no fuel/air control." It should revert back to stock, right? Although that's not ideal if you've got high flow pipes and air filter installed, you'll still be able to ride the bike for awhile until a new PC-V arrives.
  6. emmo2112
    emmo2112 New Member
    3
    yes it would go back to stock, the PC5 is just an interrupter... I guess I mean the mix wont be correct, I'm thinking it'll be on the lean side..
  7. Breeze3at
    4,926
    224
    The ECM is programmed to work with the O2 sensors to provide a 14.7 : 1 mix
    (approx) for EPA regs. Adding mufflers and air cleaners will not make it leaner, it will compensate to maintain factory specs. You will lose some performance, because your fuel pack was adjusting the system to a more optimum mixture.
  8. mc2
    mc2 Active Member Contributor
    266
    Pardon my cut in on the thread, but this brings up a thought relative to this PC V issue.
    I've removed my O2 sensors. If I had to unplug the PC and revert to stock for a troubleshoot, or emergency, would it get me down the road?
    I would unhook it and find out for myself, but I'm a bit of a wusss at zero degrees.
    Thanks
  9. Breeze3at
    4,926
    224
    Yes, many times we've suggested disconnecting the negative lead on a fueler to see if it was causing a problem. Bikes always ran as far as I can remember (I've done it).
