Ultra Classic
Hello. I having a problem with my 2011 ultra classic and could use a little advise. I'll set the background to give a little information on what the bike is doing. I have a stage 1 set up. Screaming eagle slip on exhaust, screaming eagle air filter, headers with catalytic converter removed by American custom, and Dobeck TFI tuner. Bike has only 11,000 miles on it and i have had this set up for over a year now with no problems until now. I was at a red light idling and when i started to slighly roll on the throttle the bike felt as though it wanted to stall. Now i've been noticing the problem when i shift gears to get up to speed it tends to do the same thing when i roll on the throttle. Now my question is why would this be happening now when i have had this set up for a long time now? Could the tuner get out of whack after a while and just need slight adjustments from time to time or is there and underlying problem? I was thinking that this weekend i would adjust the tuner again to see if it solves the problem. If that doesn't work I was going to change the bike back to stock to see if it still has the same problem. I know that if i take it to the harley shop they are just going to say the problem is with the tuner or is this what i should be doing? Thankyou for any advise you can give. Chris
