positive battery cable problem
Discussion in 'Sportster Models' started by jerryw618, Sep 3, 2010.
  1. jerryw618
    jerryw618 Member
    60
    6
    hello again im having a problem with the battery cable , right at the battery terminal , seems the cable is breaking im losing power but if i move the cable around right at the positive battery connection it will come back on , can i just replace the positive battery cable??? or is it tied into the whole electrical harness ???
  2. Hoople
    Hoople Account Removed
    7,198
    34
    Jerry, Those cables are separate. It should be no problem to replace. It goes from the Battery post to the Starter lug.
  3. kclute
    kclute New Member
    3
    Just replace the cable. Might want to first take cable loose from terminals first (take ground cable off first), check cable end to see if it really is breaking. Could be just a bad connection, if so, clean cable ends and terminals, then put back on.
    Good luck.
  4. TQuentin1
    4,737
    142
  5. NEWHD74FAN
    8,191
    98
    19
  6. cromedome
    cromedome Active Member
    264
    3
    Make sure it's the cable, not a broken post in the battery on the + post.
  7. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Also, if you end up swapping cables, make sure you pull the main fuse so nothing gets fried. Lotta juice flowing through those lines & all it takes is one wrong touch to create an unfortunate fireworks show.
