popping out on me
Discussion in 'Engine, Fuel and Exhaust' started by parry2k4, May 29, 2009.
  1. parry2k4
    parry2k4 New Member
    4
    i have just bought a harley sportster xlh model year 2005 it's a 883cc with a hyper charger when i have been going on a run between 8-10 miles its starts popping banging and cutting out on me then only tick over the orange engine light is on but once the engain is then cold it runs ok
    if anyone could please help
    What mods are done to it? Has it been re jetted? Need more info.
    Have you checked for fuel contaminants?
  3. glider
  4. parry2k4
    parry2k4 New Member
    4
    I do not know if it has been jetted for the hyper-charger, it has Vance and Hines exhaust system and has been standing for some months before I bought it and I had to replace the battery, thats as much as I can tell you at the moment, thanks for your help and responses.
  5. glider
    I would first open up the carb and see what jetting is in there. The low should be about a #46 and the high speed should be about a #180/185.
  6. parry2k4
    parry2k4 New Member
    4
    thankyou for that glider this is my first harley do you think the hypercharger might have something to do with it as hobbit has said cheers dave
  7. glider
    There's a good possibility, look at the link above.
  8. AutoDoc
    AutoDoc New Member
    3
    Runs ok till gets hot, then shuts down. Cools off runs again?
    Sounds electrical componet heating up and shuting down? Coil, crank sensor, module?
    May be way off base here?
