Poor radio reception
Discussion in 'General Harley Davidson Topic' started by sjcea, Jul 17, 2013.
  1. sjcea
    sjcea Active Member
    104
    My 2006 Street Glide gets extremely poor radio reception . the Harmon Kardon radio is not the original it came from a 2013 Street Glide and is brand new . I replaced the antenna with the Kuryakyn rubber whip antenna hoping that would improve reception but it did nothing . any ideas ? Or is this normal to get horrible radio reception ??
  2. gusotto
    gusotto Junior Member
    604
    38
    13
    You might check the software version.
    An update may fix your problem.
  3. sjcea
    sjcea Active Member
    104
    Shouldn't it have the latest version since it came from a brand new 2013 bike ?
  4. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
  5. STEVE07
    4,122
    68
    82
    Try pulling the seat and checking the antenna wire. Any small cuts in the coaxial can reduce reception and cause static.
  6. sjcea
    sjcea Active Member
    104
    It does not have LED . that link doesn't work and how do I apply an update if need be ?
  7. sjcea
    sjcea Active Member
    104
    Will give it a good look thanks
  8. Iceman24
    3,266
    23
    Funny, link works fine for me - should download a .zip file & then follow attached instructions...
  9. sjcea
    sjcea Active Member
    104
    Cool thanks a lot I'll look into this !!
  10. lordharold
    lordharold Active Member
    191
    If I remember correctly did you have it switched to your region I was thinking that the dealership had to use digital tech to set the radio system.
