Has anyone had as bad luck with the light bulbs this company makes as I have? (Phillips home lighting Bulbs)
I bought 6 of their spot light bulbs to use in my 3 motion sensor lights outside and after about 4 months the front glass lens falls off and breaks on the ground breaking into pieces on all of them. I got them in different stores so I doubt it could be an old stock.
The lens seems as if it is adhered with some sort of glue and that dries out and doesn't do the job it was intended to do in keeping the front of the bulb intact and in place. I also noticed that the regular bulbs they make for lamps have a VERY short life span too and require replacement.
I have sent the company 2 emails that I received confirmation for and no reply in almost 2 weeks now even thou they say they will reply within 4 days in the confirmation email.
I tried a GE flood light bulb and they are made much better in that the glass lens is an integral part of the bulb unlike the other Phillips bulbs that are glued on.
Looks like Phillips has lost a customer not only because of their crummy products but lack of a reply and caring about a problem with their product.
Too bad Phillips!
Too bad Phillips!
