Passenger heat on calf
Discussion in 'Engine, Fuel and Exhaust' started by Harleydad58, Jun 22, 2015.
  1. Harleydad58
    Harleydad58 New Member
    3
    my wife has a problem her right calf gets very hot. I have put heat wrap
    on and reinstalled heat shield its ok for about 20 mins then the heat gets intense is there a cure for that
  2. dolt
    dolt Senior Member
    2,172
    103
    333
    I solved that problem by converting the exhaust on my '02 FLHT to the '09 and later under carriage exhaust. You would need the '09 and later oil pan and a complete new exhaust system. Cheaper than buying a later model.:s
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    For about $200 you can get the "Fullsac" dual exhaust kit. It puts all the front cyl. gas through the right, and all the rear cyl. gas through the left. Right now about 75% of your exhaust is going through the right side. Easy to install with basic hand tools.
  4. Harleydad58
    3
    sounds good where can I get it
  5. Bodeen
    4,647
    73
    221
  6. Harleydad58
    3
    thanks will look into also hope this conversion don't make the left side a problem like the right is bike has stock pipes
  7. Dan.1977P
    Dan.1977P Active Member
    287
    38
    5
    She's wearing boots and pants too, right? I've heard a good tune will cool things down a bit too.
  8. Breeze3at
    4,926
    224
    The Left pipe will be hotter than it is now, but the heat will be more even. Her left ankle may get warm at stoplights. Like Dan mentioned above, a good tune
    (adding fuel,via a fuel pak. of some sort) will cool it down some.
  9. dolt
    dolt Senior Member
    2,172
    103
    333
    More expensive and more work but S&S does offer a later model conversion set of head pipes that will work with the early oil pan and compatible with your existing mufflers. Solves both right and left side heat issue for passenger and also removes the heat right under your butt. Just another option for consideration. Converting to the later cross under system made a huge difference for me and passenger.:s
    Power Tune Duals
