Harley Davidson Foorboard Kit 50602-00
Passenger footboard mounts, Qty 2., How do you determine the LH mount from the RH mount. One is 1/2 inch shorter. I kinda feel like both mounts stick out too far.
I installed the shorter mount on the left, longer on the right. On the bracket they are hexagon shaped with a notch for screw clearance. I pushed each footrest on each hexagon completely. Marked where the bolt went, then cut new notches in the hex. This brought the footrest in an extra 1/2" on each side. The footboards (folded down) still extend out 4" on each side further, than the original footpegs did. All I know now, is that is to machine the bracket down to get the footboards in closer.
This was not a good HD design. Small Wings!
