Rocker box gasket kit is where i would start it is not un common for the lower rocker gasket to leak there is an upgraded metal gasket in the kit it replaces the 2 part paper lower gasket
the place where mine is leaking is typical i have heard, but its on the rear cylinder on the top back of the engine. would the gasket kit be a fix for that?
If the leak is above the exhaust port then it is most likely one of the rocker cover gaskets usually the lower gasket part number 16800-84A is the current part number for the lower rocker gasket on your bike
