Part number for Stock Pipes
Discussion in 'Engine, Fuel and Exhaust' started by tlyoungb, Mar 20, 2011.
  1. tlyoungb
    tlyoungb Junior Member
    441
    Hey,
    Can someone here help me out. I am looking for the part number for the stock pipes for a 2005 Electra Glide Standard FLHTI.
    I don't know if they are catalytic Converter or not.
    Thanks
  2. ZZroadking
    ZZroadking Member
    74
    Tlyoungb,
    California bikes are catalytic in 05- Left side chrome #65418-04
    Non California (domestic)- Left side chrome #65538-95A
    California chrome catylitic- Right side #65354-04
    Right side domestic chrome #65539-95A
    There are also slash cut part #s in my 05 Touring parts manual( page 131) which I am using if you need. Should be correct but I suggest you cross ref with your local HD shop just to be sure.
    Good luck.
  3. tlyoungb
    441
    What if there is the letter B instead of the letter A.
    Thanks
  4. fin_676
    5,788
    153
    287
    The letter at the end of the part number will indicate the revision of that part but the fitment is the same so a B at the end will be an updated or revised part newer than A
  5. tlyoungb
    441
    Well here is more info I found. Looking at these pipes, I saw the pipe that goes on the right side(Sitting on the bike) has the part number 65846-95B, and the USA Catalyst stamped on it.
    The other side has 65538-95B.
    So I am thinking now that these pipes have the catalytic converter in it and the other side doesn't. I was wanting to put these on my 2005 EGS FLHTI, but I am thinking that my bike does not have the catalytic type. My pipes are in bad shape, and a friend of mine gave me these pipes. Can I use them? or should I just pass on them.
  6. Jack Klarich
    I would pass on the Cat pipes JMO My take is it will de crease your exhaust flow
