free website stats program P1511 09 ultra | Harley Davidson Forums
P1511 09 ultra
davey1903
I'm baffled!
I put the bike up on the jack to do some cleaning. While it was on the jack I started it and put it in 1st gear just to spin the rear wheel. Let it spin for about 30 seconds and then shut it down. I took it off the jack and went to start and had a hard time getting to start. Found the p1511 code and cleared it. I went out for a ride and everything seemed fine. About 5 miles out it went into limp mope. Pulled over and the code was back. Cleared and everything was fine but it keeps happening
Any umput would be appreciated
You can start with disconnecting the throttle actuator inspect for water and corrosion, reconnect/ disconnecting it a few time to clean the pins.
I have read about water contamination in the connector from the throttle down to the main harness inside the fairing.
But most fixes seem to be the throttle actuator motor.
You shouldn't ride the bike until you get it fixed.
