66cruiser Active Member Apr 29, 2009 #1 Had the inner primary bearing replaced & now have a slight leak where the shift rod comes out of the outer case. Any suggestions as to what may cause this?
G glider Veteran Member Apr 29, 2009 #2 There's a gasket between the inner and outer where the rod comes through. Possible they reused the old gasket?
66cruiser Active Member Apr 29, 2009 #3 Pretty sure he used the old one.. got a new one on order. Thanks glider!
