Optimum Outside Temp
Discussion in 'Touring Models' started by CalRider, Dec 21, 2010.
  1. CalRider
    CalRider Member
    25
    I have noticed that my bike runs best when the outside temp is about 40 to 50 degrees, but I have never had it out in temps much below 40. It could be that it runs even better in those temps???? What would you say is the best outside temp for the bike?
  2. Jack Klarich
    Dont know that there is one once you factor in humidity and elevation, tho my bikes have always run strong @ or below 50:s
  3. like jack said theres a lot of factors. i do know we never start a drag race when temps are below 45°f
  4. Hoople
    Hoople Account Removed
    7,198
    34
    As Jack said, humidity plays a Big role in how much oxygen there is in a given amount of air. But as you can see even at temps to -13F, the density of air keeps getting larger. (This just shows how much O2 there would be in a given amount of air vs the temperature and nothing more)
    Effect of temperature vs air density
    Temperature Density of air
    in °C vs volume of O2 ρ in kg·m−3
    +35 1.1455
    +25 1.1839
    +20 1.2041
    +15 1.2250
    +5 1.2690
    ±0 1.2920
    -5 1.3163
    -10 1.3413
    -15 1.3673
    -20 1.3943
    -25 1.4224
  5. johnkarlfl
    johnkarlfl Active Member
    168
    Not sure about the bike, but I don,t run at all below 40 F
    :D
  6. Jack Klarich
    Wow, I had no idea, great find Hoop:s
  7. HarryB737
    HarryB737 Junior Member
    656
    I think the optimum outside temp is between 72-75* Fah.... The bikes operator is much happier.. :D
  8. gator508
    gator508 Well-Known Member
    2,754
    179
    Ha-ha-ha, big 10-4 on that!
  9. Porter
    Porter Junior Member
    534
    4
    This morning, it was 26 leaving the house and when I got to work the oil temp gauge read ~180 F. That to me is a big difference over the 240-270F readings I get in the summer when it is 90F+. Air density plus ~100 degree F differnce (at least by my oil gauge) has got to change something.
  10. wv2wheel
    wv2wheel Active Member
    154
    I was also going to say air density and the fact the motor can cool much better. A cool dense air charge always will give a bigger bang...at least that was what I always thought.
