free website stats program OOPS!!!! | Harley Davidson Forums
OOPS!!!!
While changing the clutch in a 2013 street glide, I accidently hit the clutch lever and the pushrod almost fell out, was about 3" hanging out of the spline for the clutch basket. Can I just push it back in and be ok? Or is there something that may have moved and needs to be checked? I have looked through the service manual but can't find anything. I do know it does not move much as it is actuated by the three balls in the release mechanism in the transmission side cover.
Yes you can push it back in w/o any problems. Why did you have the center adjusting screw/plate out? If you didn't change the center adjusting screw setting then you won't have any problems.
tourbox
