Only Rear Turn Signal LEDs, Need Equalizer?
Discussion in 'Electrical' started by mrglide, Oct 20, 2009.
  1. mrglide
    mrglide Member
    77
    18
    I have read a few times that if ONLY the rear turn signals are changed to LEDs that a load equalizer is not needed. One vendor during Biketoberfest at Destination Daytona also had a sign to that effect.
    Can anyone confirm this? Is it true for a bike with the TSSM module?
    The TSSM will self adjust but only to a degree. Some LED's draw less than others and the TSSM will adjust to them otherwise a load equalizer will be needed.
  3. mrglide
    mrglide Member
    77
    18
    glider,
    Thanks for an answer that makes sense. :)
    Is there any way to determine which ones might work w/o an equalizer?
  4. glider
    Only based on second hand info and what the manufacturer may say.
  5. mrglide
    mrglide Member
    77
    18
    Thanks again.
    :cheers
  6. Elmosac
    Elmosac Active Member
    174
    I can tell you the Kuryakyn LED turns will require an equalizer if you don't do both front and rear.
  7. mrglide
    mrglide Member
    77
    18
    And what happens if you do both?
