One side turn signal not blinking
Discussion in 'Electrical' started by ADragon, Oct 3, 2010.
  1. ADragon
    ADragon Member
    I have a 1992 Dyna FXDB, the alternator plug kept popping out and the battery was drained down to the point that the turn signals stopped working. I brought a retaining clip from JP Cycle to make sure that the alternator plug from popping out. However, after the battery was charged back up, only one side signal worked. The other side running light would stayed on but when I activated the turn signal, it would not blink. Can anyone one help me pin point what the problem is so I can get the right part to make the repair. I have checked the signal switch already and it works and I am running out of thing to check.
    Thank you in advance.
  2. 2000classic
    2000classic Active Member
    301
    Check the front and rear bulbs on the side that is not working. One of the bulbs may be burned out.:(
  3. fin_676
    5,779
    153
    285
    front bulb has 2 filaments a low wattage one for running lights and a high wattage one for the indicator so just because it is on for running lights does not mean it is good
  4. Jack Klarich
    Check both contacts with a test light
  5. ADragon
    ADragon Member
    Thanks for the information, I will do a swap of the good side with the bad and see if it would tell me more.
  6. ADragon
    ADragon Member
    As it turned out, it was the turn signal canceller. One side just would not blink. After over $200 for a new canceller from the local HD dealer, everything is fine now.
  7. Hoople
    Hoople Account Removed
    7,198
    34
    Out of all the things it could have been, it turns out to be the most expensive part. That is the way my luck runs...
    Glad your up and running.
