Oil Problem
Discussion in 'Engine, Fuel and Exhaust' started by rgoot01, Jan 15, 2014.
  1. rgoot01
    rgoot01 Member
    82
    So I adjusted the primary chain and added fluid as needed the other day. I also checked the engine oil and topped off as needed. First off the reason I adjusted the primary chain was due to excessive noise. There was very little oil in primary which was odd given I had checked it two weeks prior. Since adding the primary oil I now have oil coming out of the crankcase breather. When I checked the engine oil it was fine.
    Could the reason I am losing primary oil and yet I always have enough engine oil and am blowing oil out of crank vent be a bad crank seal?
  2. dolt
    dolt Senior Member
    2,185
    103
    341
    It would help to know bike model and year.
    [​IMG]
  3. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    ALSO, IF Older bike like you show in your Avatar, Usually with the engine seal gone, they Leak oil out of the motor INTO the primary, filling it up...
    Oil out the vent tells me TOOOOO much oil in the primary...
