on my 2001 (FLHTCUI Ultra Classic) my oil light flickers after starting cold or hot, the oil press is 8 psi at idle and 35 psi around 2000 rpm. I have checked the oil sending unit on front of motor for a loose wire, i unplugged it and the gauge stops working but the light continues to flicker. Is there a different wire I should be checking to see if it is loose? any help would be great!!!
