I have a 2000 EGC, 8K and have developed a slight oil leak. Several drops upon returning from a ride. The dealer recently changed all fluids,
Amsoil20/50, Redline Heavy, and HD Formula+. I thought I solved it when I found the engine oil drain plug loose and leaking but I still have a leak. The front sparkplug was also hand loose.
The leak seems to be coming from somewhere in the area where the chain case and the crank case join together. Is this an area that is prone to leaking? The fluid that is leaking out appears clear on the piece of paper that I used to try to locate the source of the leak.
Does anyone know of a technique that I could use to find the source of the leak?
Thanks for the help.
