Oil Leak
Discussion in 'Sportster Models' started by fwcole, Oct 1, 2009.
  1. fwcole
    fwcole Active Member
    189
    My brothers sporty has had a problem with oil coming from the air cleaner. We checked the breather lines for clogs and they were clear, any suggestions?
  2. 03classic
    03classic Junior Member
    424
    possible oil overfill.
  3. springer03
    springer03 Active Member
    141
    More than likely Oil overfil!
  4. fwcole
    189
    No this has been a long term problem, weve checked alot of things others have suggested but havent been able to figure it out
  5. fwcole
    189
    Service manual points to crankcase breathing problem
  6. fin_676
    5,790
    153
    289
    I need a bit more info before i can make any sensible replies as they have been making sportsters since 1957 you could start with year of manufacture
    any mods especially to the air cleaner and carb it all helps
    but if its a solid mount evo engined sportster may be the umbrella valves have hardend this could cause your problem
    However be aware that there is oil mist in the air coming from the breathers this oil mist should be fed into the carb so that it can be burnt in combustion if the air flow isnt correct the oil mist can condense in the air cleaner and drip out
  7. fwcole
    189
    96 sportster 1200 drag pipes, high flow air cleaner.All these were there before the problem started, and we have already changed the umbrella valves
  8. hippie13
    hippie13 Active Member
    116
    my 91 would drip oil from the se air cleaner ' for years' only when you ride it hard tho and i changed 'everything' lol finaly i ran it with the air cleaner off and found it pushed quite abit out of the breather bolts. now idk if this was the right thing to do but it definatly helped.
    i took the washers off the breather bolts so the bolts sit further into the heads , not much mind you, but did help. it still breaths but the flow is less. like i said idk if its the proper thing to do but it dnt cost nutn to try . just make sure the bolts dont bottom out or seal up the flow ;-)
    they do make breather kits but i ddnt find one that fit nice
    peace
